AutoCAD Forum
deleting unreferenced image files from command line
3 REPLIES 3
1362 Views, 3 Replies
Is there a way to get rid of the unreferenced image files from a drawing from the command line. I have thousands of dwgs to batch edit using a script and Script Pro and need to automate the "right click and detach" on the command line.
any help much appreciated Gareth
3 REPLIES 3
Neil47
You can use -image at the command line
maxim_k
Welcome to the Autodesk Forums!
Please look here:
http://blog.jtbworld.com/2009/06/purge-unreferenced-images-in-autocad.html
and here:
http://www.jtbworld.com/smartpurger.htm
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: Neil47
Thanks, I know it sounded basic but I was attempting to use wildcards, also
good that -image doesn't kick up errors from an incorrect list
cheers
Gareth Lowe
Spatial Techniques Limited
m. +44 7710 940253
”Boost
