AutoCAD Forum
constraints removed
4 REPLIES 4
m.pharamawy
314 Views, 4 Replies
constraints removed
hi everybody. i face a critical problem. in the attached file , this is a section , i used a collinear constraint to keep the levels attached to the lines which indecate them. now , if i copied the section with the levels . the constraints of some of the levels will be removed rondomly. i dont know why ?
please help
4 REPLIES 4
nestly2
in reply to: m.pharamawy
I was not able to replicate your results.  I even used copy/paste to copy the 7 blocks to a new drawing and all the contraints seem to remain.   You have results different that what's shown below?
m.pharamawy
No I mean the copy command
Try to copy all the items by normal copy command.
One or two levels will not be constrainted anymore.
To make sure. After u copy them. Try to select only the section block and move it on y axis ( virtually ) some levels will not move with u.
Thanks for ur reply.
m.pharamawy
**vertically
m.pharamawy
in reply to: nestly2
AS PER UR MOVIE SKETCH , I THINK THAT THE CONSTRAINTS OF SOME LEVELS HAD BEEN REMOVED. CHECK THAT AFTER MAKING COPY.
”Boost
