I am adding text by using Single Line tool.I have used Arial style.How do i changed the Text from Arial to other Text styles please....Rich - Autocad 2014
Solved by Alfred.NESWADBA. Go to Solution.
if you want to redefine the style you can use the command _STYLE and assign another font to a named textstyle (a REGEN might be necessary so all existing textobjects with that style get updated)
If you want to assign another style to an existing text-object you can select the text-object and change the assigned style in the property-window.
If you have MTEXT-objects where there are parts of the text overwritten with other fonts then you have to double-click them and set their font assingments back to the style.
At least it depends on what type of text-like object you are writing about.
- alfred -
