AutoCAD 2013/2014/2015
mr-_-small
Message 1 of 3 (791 Views)
changing block units
791 Views, 2 Replies
12-03-2012 06:38 PM
i looked for this problem but it seems impossible, i have a dynamic block and it unit is unitless . i want to change it to mm .
if i use the command " bmake " the dynamic block will be lost because autocad will redefined the block and it can not redefined dynamic block.
also its a complicated block i can not make it again .
Alfred.NESWADBA
Message 2 of 3 (784 Views)
Re: changing block units
12-03-2012 08:37 PM in reply to: mr-_-small
With _BMAKE you create a new block-definition. But as I understand your situation you already have a definition and you want to edit/modify that. In that case you should use _BEDIT (>>>details<<<) to get into the blockeditor, there you can set the block-units within the property-window (<CTRL> <1>).
- alfred -
Alfred NESWADBA
mr-_-small
Message 3 of 3 (772 Views)
12-04-2012 04:34 AM in reply to: mr-_-small
yaaaa you are the man .... thank you alot .:smileyvery-happy:
that exactly what i want .. you are awesome.
i search for this in this fourm but no such an answer like this ...  glad you here...
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
