Solved by GrantsPirate. Go to Solution.
You create a block that looks like the red arrow, one unit in length, have it pointing to the right, draw from 0,0.
Edit your dim style to use the arrow you just created.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
