Hello all, I am working on a drawing and typically when I double click the title block all the boxes highlight and I can go into properties and change the text in the blocks. On this drawing I am working on now when I double click the title block only the line that I click on highlights. On another one when I click the title block just the outline highlights and I get a blue grip box in the lower right hand corner. Did I change something I shouldn't have?
Solved by pendean. Go to Solution.
Solved by doni49. Go to Solution.
Your statement that only the line you click on highlights leads me to believe the titleblock has been exploded. If it were a block with no blocks, the ENTIRE BLOCK would've highlighted.
Don Ireland
Engineering Design Technician
@Anonymous wrote:
I think you are correct I had an issue and someome reccomended exploding the drawing but how do I go back?
If you've exploded and can't go back via the undo command, then the only way would be to delete what's there and re-insert the block. Or if there's a backup available, you could use that.
Don Ireland
The dwg file you posted has a block with NO ATTRIBUTES on the "hel rd bare other" tab. The "hel rd bare one" tab has an exploded block.
Don Ireland
Ok thanks is there a way I can add attributes, or fix the exploded block. Sorry but I am new at this and I appreciate the help. If I did something wrong I can fix it next time. Thanks
