AutoCAD 2013/2014/2015
Message 1 of 9 (735 Views)
can't delete holes in surfaces....
735 Views, 8 Replies
04-16-2012 11:41 AM
Hi, I have attached a file that has a surface, with holes in it.  I need to heal the surface, or remove the holes.
In old mechanical desktop, when you untrimed the surface, the holes would go away. Now untriming does not eliminate the holes and extending the surface inward does not work either.
Am I missing something?  This seems like it would be a common task to need to be able to do with surfaces.
Thanks!
*Expert Elite*
Message 2 of 9 (705 Views)
Re: can't delete holes in surfaces....
04-18-2012 07:01 AM in reply to: hypersonic
In old mechanical desktop.....
Hasn't been sold as a product by Autodesk since Feb 2002.
Most users doing this type of work have updated to Autodesk Inventor.
Inventor indicates quality problem with your surface.
I was able to get Inventor to Refit the surface to pass quality check.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
*Expert Elite*
Message 3 of 9 (703 Views)
04-18-2012 07:07 AM in reply to: hypersonic
Using a modern program like Autodesk Inventor it is trivially easy to untrim the surface.
In this case I elected to remove the wires (boundaries of the holes), but they could be kept if needed for reference.
Active Contributor
Message 4 of 9 (680 Views)
04-18-2012 10:50 AM in reply to: hypersonic
Done with Acad 2013.
Thanks Autodesk for AutoCAD's evolution.
*Expert Elite*
Message 5 of 9 (670 Views)
04-18-2012 12:00 PM in reply to: PaulCloutier
Doesn't look like the same surface to me?
Message 6 of 9 (638 Views)
04-19-2012 07:11 AM in reply to: JDMather
Would Fusion do the same stuff?
Message 7 of 9 (636 Views)
04-19-2012 07:16 AM in reply to: PaulCloutier
Paul, what commands did you use to do this in AC2013?
Thanks!
Active Contributor
Message 8 of 9 (627 Views)
04-19-2012 10:20 AM in reply to: hypersonic
Xedges
or
Solidedit -> Edge -> Copy
Edges are turned to splines or arcs
For arcs then -> Pedit -> Spline
Use Join to join Splines (use the grips and Osnap END if the dont join)
Must have 4 Splines to use Surfnetwork (two sides and both ends)
You can modify the new surface U and V isolines in the properties
This is my way...maybe a better one ?
Message 9 of 9 (621 Views)
04-19-2012 11:20 AM in reply to: PaulCloutier
Yes, but then I think you might loose the surface shape that it had originally, I think that is what JD might be trying to point out.....
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
