AutoCAD Forum
can only see most, but not all, of layers in layer manager
1 REPLY 1
237 Views, 1 Reply
I remember that there used to be a command I used in an older version of AutoCad, such as "Sort Layer" or similar that would populate all of the layers used in a drawing, which solves the problem of not being able to see all the layers. I believe the default value is not set at a high enough number.
Does anyone remember what this command is?
1 REPLY 1
Patchy
maybe MAXSORT
”Boost
