I remember that there used to be a command I used in an older version of AutoCad, such as "Sort Layer" or similar that would populate all of the layers used in a drawing, which solves the problem of not being able to see all the layers. I believe the default value is not set at a high enough number.
Does anyone remember what this command is?
Solved by Patchy. Go to Solution.
