I just got a new tower and had to install my suites again. In doing so I lost all the fonts I had accumulated over time from projects. I was searching on how to check if I had the font and read a forum that told me to type in a command and set the default to Old English vs Standard. I did, closed the window and went on my marry way.
Now everything is old English and I just want to have standard back. Does anyone know the command to do so?
1 command to set standar default
next promt to type in code for standard.
Any suggestions would be greatly appreciated.
Solved by Patchy. Go to Solution.
