I draw a circle with radius 2', and I create a block and do the attribute definition. When I inserted the block, it turned out to be an 2 3/8" inches circle. I tried several times, but the results are the same.
Here is my step:
1. draw a 2' circle
2. create a block (attached the block definition)
3. the Block Editor is opened, command : attdef ( attached the attdef)
4. Place the elevation_tag# at the center of the circle
5. save the block
6. close block editor
7. command: insert, I inserted the elevation tag
8. I attached the inserted block, when it compares to a 2' circle, it is obviously smaller.
Is it possible to tell me the steps that I am missing? Thank you
Check the block definition see if it is an annotative block. You can redefine it to set annotative to 'No' and then scale all insertions afterwards.
you defined the block as "unitless" (see your screenshot "block definition.png"), so when inserting a block with "unitless setting" the sysvar INSUNITSDEFSOURCE (see also command _OPTIONS ==> tab "User Preferences") will be used for insertion-scaling.
- alfred -
