AutoCAD 2013/2014/2015
Member
bramdom123
Message 1 of 3 (6,338 Views)
autocad vs autocad architecture
6338 Views, 2 Replies
07-10-2012 03:37 PM
what is the difference between this two software.
both have the same autocad clasic version inside?
*Expert Elite*
pendean
Message 2 of 3 (6,337 Views)
Re: autocad vs autocad architecture
07-10-2012 03:39 PM in reply to: bramdom123
AutoCAD is present in both.
ARCHITECTURE has walls/doors/roof/floor/window/sections/details/construction/schedules features plain AutoCAd does not, all geared towards those in the ARCH industry.
Plain AutoCAD is aimed at no one and has none of these abilities built in: it doesn't know a wall from a line for example, or a door from a widget.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
*Expert Elite*
dbroad
Message 3 of 3 (6,313 Views)
07-11-2012 06:16 AM in reply to: bramdom123
As Dean said, lots of differences.  You can download it and use it for 30 days free. Try and see.  For me, the detailing features alone are worth the price.  If you're going to do architectural design in AutoCAD, I highly recommend using AutoCAD architecture.  You can use as much or as little of the objects.  Only downsides are fairly steep learning curve and upward only compatibility.  Revit is the more complete BIM solution.
See also:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=18781653
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
