dear sir
when i open some file in autocad, message appear as below.
" autocad is running out of system memory, continuing the current command may result in program failure or loss of data,
do you want to cancel the current command "
if there are any solution for this.
thanks
Hello
Are you running on a 32 bits Windows ?
If YES, please you must know that the 32 bits "ACAD.exe" task is limited to about 1.3 Gb Ram used !
It's a limitation of "ACAD.exe" 32 bits versions 20xx-201x ...
Patrice BRAUD
