I created multiple base views and projected views on drawing (autocad 2014). suddenly when I create base view it doesn't show anything, jumps to 0,0,0 coordinates (it is fixed can't be changed), scale can't be changed. It shows it is drawing view in properties, however when I want to edit (click edit then select the view , it won't recognize it is view). I created many views without problem, now all base views jumps to 0,0,0 coordinates....
(pic 1 )- shows the usless view
pic 2 - shows previous view without any issues
Would it be possible to provide the file where this issue is occuring? This will assist in further troubleshooting this issue.
Has anyone found a solution to this? I am getting this problem consistently across a number of drawings and computers.
