AutoCAD 2013/2014/2015
fiesty
Message 11 of 30 (213 Views)
Re: autocad 2013 opening older version
05-03-2013 08:25 AM in reply to: Jay_B
PROXYSHOW is set to "1". The drawing does not open up at all. Autocad is shooting blanks
fiesty
Message 12 of 30 (212 Views)
05-03-2013 08:25 AM in reply to: Alfred.NESWADBA
I do have the latest service pack
*Expert Elite*
Alfred.NESWADBA
Message 13 of 30 (203 Views)
05-03-2013 08:34 AM in reply to: fiesty
something I would never suggest (normally), but try the following:
a) start both, AutoCAD 2011 and AutoCAD 2013
b) open the problem-drawing with 2011
c) (in modelspace) start command _COPYBASE, point 0,0,0/some objects to select
d) change to AutoCAD 2013
e) run command _PASTECLIP ==> what happens now?
Other option: run command _SAVEAS and save the drawing back to DWG2000 or DXF12 (try both) ==> and open then these files.
It might be possible that some objects are not transfered then, but it is interesting first if you get some elements into 2013.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
fiesty
Message 14 of 30 (200 Views)
05-03-2013 08:41 AM in reply to: braudpat
I can not send dwg, file size to big (even zipped)
*Expert Elite*
dgorsman
Message 15 of 30 (196 Views)
05-03-2013 08:54 AM in reply to: fiesty
Hardware and OS specs, please?
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
*Expert Elite*
pendean
Message 16 of 30 (189 Views)
05-03-2013 09:56 AM in reply to: fiesty
There are many services you can use to share big files on forums, like wikisend.com and many others. Get one, I think it's important for others to see what is wrong with your file (if anything) or with R2013.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
fiesty
Message 17 of 30 (170 Views)
05-08-2013 01:59 PM in reply to: pendean
here is a scaled down version (I had the creator to strip out alot of unimportant details) still I can not open this.
time is running out
fiesty
Message 18 of 30 (166 Views)
05-08-2013 02:07 PM in reply to: dgorsman
acer travelmate 8572t, windows 7 32bit i5 cpu 4gb
Valued Contributor
ricardo_baez
Message 19 of 30 (153 Views)
05-08-2013 02:43 PM in reply to: fiesty
I tried opening your drawing with Autocad 2014 and it prompted me to do a RECOVER on the file.  I tried opening the drawing with 2013 and I have the same issue you do.  Within 2014 command prompt I typed RECOVER and got the following message.
The file will open after running the RECOVER command, but it has to be run each time you open the drawing. There is something definitely wrong with this file.
Ricardo
*Expert Elite*
dgorsman
Message 20 of 30 (146 Views)
05-08-2013 02:54 PM in reply to: ricardo_baez
I've got little trouble opening it with AutoCAD 2011 (I've got Civil3D object enablers installed), aside from a minor warning about AEC version content.  It also has a non-AutoDesk DWG warning so I suppose the contents may not conform to AutoCAD standards in places.
If the original file is much, much larger I could see some problems with opening this with a 32-bit/4 GB computer.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
