AutoCAD Forum
attribute duplication text
3 REPLIES 3
shavezkhan
323 Views, 3 Replies
dear all i am using autocad 2014 .i got one drawing in this drawing there are attribute text & all these text have their duplicate ,so please tell me how i can delete all these by one command
i have used ovekill,filter but cant solve my problem
3 REPLIES 3
in reply to: shavezkhan
If I understand correctly it is not the block that is duplicated but the attribute? Could you try using block editor (BEDIT) to erase one of the duplicated attributes, save the changes and then use ATTSYNC to update all the instances of the block.
steven-g
can you post the drawing, so someone can check it
RockyBrown4134
Try ATTSYNC, as Neil47 suggested, if nothing else to reset the attributes to there correct position. Then evaluate the block to see it still has a duplicated attribute. from experience, I have had users that had weird things happen with title blocks. The block could have been redefined and someone forgot to re-sync it. You may want to run AUDIT command to check/fix for errors.
Hope this helps.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
”Boost
