even i've already used pu or DGNPRUGE or checked with WB, even deleted most of the lines, however the file still saved as about 25MB???!!
like this file
http://freakshare.com/files/5jbwssmn/20140321_new.dwg.html
Solved by p_mcknight. Go to Solution.
Also, check your layer filters. Some old drawings end up with a ton of these. If all else fails, you can try superpurge, if you do a search for it you can find a link to their website. Also, if you have online storage, post a link to the drawing here and we can take a look at it.
it still didn't work @@
so i uploaded a link with one of the file with this problem
I downloaded your file and checked it. The problem is with your parametric constraints. I didn't dive into how many you have or anything but once I deleted all constraints the file dropped to less than 4 megs.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
yas, i finally found that this it the problem three hourrs after i post the text here!!
also thank u guys so much, and i learn more ways to solve the problem!!
u guys are so kind!!!!!!!!!
