Need help.....I am currently working on a 3D model, and trying to use xyz filters in order to draw an accurate outline of the model my working plane.
Whenever I input PL, and then type .XY it snaps to the the correct place. However, when I choose to enter the value for Z (which in this case is 0) it does not snap to the correct location.
I use filters on a daily basis, and have had no problems until this morning, and it is doing the same thing on every drawing that I open. Hopefully it's just a matter of fixing something in my settings.
Any help would be very much appreciated.
Thanks.
P.S. My snaps are turned on......
Plines will only work in one plane, use line or 3dpoly for your work.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Good point....but not the problem. My UCS is in the correct position.
Thanks, though. I appreciate the effort to help.
GrantsPirate.......Tried that, and still get the same results. Thanks for trying.
Is this in 2015?
GrantsPirate
Found the problem....somehow my dynamic UCS was turned on, and that was causing the problem.
Thanks, guys. I appreciate your efforts.
