AutoCAD Forum
XYZ point filters are not snapping correctly (making a 2D dwg from a 3D model)
6 REPLIES 6
509 Views, 6 Replies
  Need help.....I am currently working on a 3D model, and trying to use xyz filters in order to draw an accurate outline of the model my working plane.
Whenever I input PL, and then type .XY it snaps to the the correct place.  However, when I choose to enter the value for Z (which in this case is 0) it does not snap to the correct location.
I use filters on a daily basis, and have had no problems until this morning, and it is doing the same thing on every drawing that I open.  Hopefully it's just a matter of fixing something in my settings.
Any help would be very much appreciated.
Thanks.
P.S.  My snaps are turned on......
6 REPLIES 6
dtiemeyer
I don't use those filters, but I'm wondering if your UCS is correct when you attempt to use them? Often times the UCS will rotate, then Z direction is no longer what you assume Z direction is. That might cause the filters to fail. Remember UCS is viewport specific. Just a thought, HTH.
My other CAD is a Cadillac and I like to Revit to the Max!
GrantsPirate
Plines will only work in one plane, use line or 3dpoly for your work.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
in reply to: dtiemeyer
Good point....but not the problem.  My UCS is in the correct position.
Thanks, though.  I appreciate the effort to help.
in reply to: GrantsPirate
GrantsPirate.......Tried that, and still get the same results.  Thanks for trying.
GrantsPirate
Is this in 2015?
GrantsPirate
EXPERT ELITE MEMBER
Found the problem....somehow my dynamic UCS was turned on, and that was causing the problem.
Thanks, guys.  I appreciate your efforts.
”Boost
