AutoCAD 2013/2014/2015
New Member
joleinick
Message 1 of 4 (470 Views)
XREF titleblock plotting too light
470 Views, 3 Replies
01-04-2013 01:38 PM
Working in AutoCAD 2013
Plotting from the Layout - Model is plotting fine, XREF Titleblock is plotting out too light, about 20% of what model plots.
XREFd on 0 layer (tried on different layer, result = no difference) all other aspects of plot are correct
XDWGFADECTL set at 1
LAYLOCKFADECTL set at 1
Print Preferences
- line and text (not photo)
- dpi 600
I found a work-around but it isn't realistic in the longterm, I inserted the Title block as a BLOCK and exploded it, and then the titleblock plotted fine with each of the different Title Block layers plotting correct to pen width.
I would be obliged if a more experienced user could help me correct this problem.
Best Regards,
Jon e O
*Expert Elite*
GrantsPirate
Message 2 of 4 (467 Views)
Re: XREF titleblock plotting too light
01-04-2013 01:47 PM in reply to: joleinick
Go into the layer manager,  pick an xref, is Transparency set to other than 0?, what is the plot style set to for each layer within the xref?
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
*Expert Elite*
pendean
Message 3 of 4 (449 Views)
01-05-2013 06:49 AM in reply to: joleinick
We do this all the time with no issues: can you post your titleblock (minus sensitive info) and a top file it is XRefed into to (also minus sensitive info) along with your plot style table for us to experience your issue?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
joleinick
Message 4 of 4 (416 Views)
01-15-2013 06:07 PM in reply to: GrantsPirate
Thank you for responding Transparency - All 13 layers are set to 0 Transparency Plot Styles - 12 different Colors, 2 Colors shared by 2 of the 13 layers. Best Regards, Frize Corporation - P# 626-369-6088 Jon E. Oleinick - C# 626-786-9186 16605 E. Gale Ave. Industry, CA 91745 "The difficult we will do today, the impossible will be done tomorrow" - Jim Frize
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
