Is it possible to write text in the text box (MTEXT) by typing text in the command line?
Solved by pendean. Go to Solution.
Unless you have modified your PGP file, if you type T in the command line you will get MTEXT. If you type TEXT, you will get single line text. You can change it in the PGP file if you want.
