AutoCAD Forum
Writing LISP to load layers with Description
7 REPLIES 7
Message 1 of 8
perkins76
1456 Views, 7 Replies
I need some help with my LISP.
I am trying to load all of our standard layers to include the layer name, color, linetype and description.  The routine works the first time it is run, but if someone re-runs it (i.e. they delete a layer, etc.) the promts change to add in the despription... after the 1st time it asks if you want to replace the current description.  I cannot figure out how to make this work both the first time (w/o the extra promt) and the 2nd time (w/ the additional prompt.Any help would be appreciated.
Here is a sample of the code.
(defun c:FPlayers ()
(command "CMDECHO" "1")(terpri) (prompt "Setting layers")(princ)
(command "layer" "unlock" "*" "thaw" "*" "on" "*" "")
(command "layer" "m" "0" "c" "7" "" "l" "Continuous" "" "")
(command "layer" "m" "A-COLS" "c" "yellow" "" "l" "Continuous" "" "")
(command "layer" "d" "Columns" "A-COLS" "")
(command "layer" "m" "A-COLS-GRID" "c" "40" "" "l" "CENTER2" "" "")
(command "layer" "d" "Column Grid" "A-COLS-GRID" "")
(command "layer" "s" "0" "")
(prompt "All layers are set")
(princ)
);end defun
7 REPLIES 7
Message 2 of 8
rkmcswain
in reply to: perkins76
IMO, this is exactly the type of situation where the sysvar EXPERT should be honored, but I guess today's current "-layer" programmers didn't know it existed or chose to ignore it for some reason.  You can use this function instead.
(defun foo (layer desc)
  (vla-put-description
    (vlax-ename->vla-object
      (tblobjname "Layer" layer)
 desc)
;;; use like this
(foo "0" "My Desc")
Message 3 of 8
perkins76
in reply to: rkmcswain
Message 4 of 8
rkmcswain
Include the function (defun foo.....) inside your lisp file.
You can rename the "foo" to something else if you like.
At the point in your other code where you want to set the description, then call the "foo" function like this:
(foo "layer_name" "description")
"layer_name" is the layer you want to modify
"description" is the description you want to use
Both arguments must be strings
Lastly, there is no error checking so if you pass this function a layer that does not exist, or a description that is not a string, etc., it will fail.
Message 5 of 8
Kent1Cooper
I'm not at a station with a new-enough version to have the Description option in the Layer command, but when it asks whether you want to replace the Description, is the default option "Yes"?  If so, I can suggest another way to do what you're after.
Kent Cooper, AIA
Message 6 of 8
rkmcswain
in reply to: Kent1Cooper
The default is "N" on 2015.
Command: -LAYER
Current layer:  "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: d
Enter layer description: test
Enter name list of layer(s) to apply description or <select objects>:  <*>: 0
Replace existing description(s)? [Yes/No]:? <N> y
Command:
Command:
Message 7 of 8
Kent1Cooper
By the way, ignoring the replace-the-description problem, you are apparently unaware of the fact that you can do a whole batch of Layer option operations within one Layer command, so you don't need to end it and get back into it all those times:
(command "layer"
  "s" "0
  "" ; terminate the one collective Layer command
If the default on replacing a Description is Yes, the other approach I will suggest will require breaking that into a few pieces, but most of it can remain in one Layer command.
Kent Cooper, AIA
Message 8 of 8
Kent1Cooper
....Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]:
In that case, here's a really cheap trick you can try:  Since Yes is not an option in the "base" Layer sub-prompt, you can supply that as an answer to the mere possibility that it might ask that question.  In the individual-Layer-commands approach:
(command "layer" "d" "Columns" "A-COLS" "_yes" "")
If there's no description for it to ask whether you want to replace, an "Invalid option keyword" message will go by, but it will then just go back to the base prompt and carry on, in the above case to the Enter that closes the Layer command.
But that also has the advantage over the other suggestion I was going to make [if the default was Yes], that it ought to work in an overall-combined-into-one-Layer-command approach:
(command "layer"
  "d" "Column Grid" "A-COLS-GRID" "_yes"
  "s" "0
Kent Cooper, AIA
”Boost
