AutoCAD 2014 offered a range of tools for working with pointclouds (croping and extracting features), having upgraded to 2015 these tools are no longer recognised.
Is there a solution to this (other than moving to other software)?
Solved by tony.millington. Go to Solution.
Welcome to the Autodesk forums
I don't use Pointclouds myself, but I've seen that some of the tools have been improved/replaced, such as Point Cloud clipping vs cropping. Here's a couple Autodesk videos that may be helpful.
http://www.youtube.com/watch?v=aCqS9TBH3sQ
Thanks for that info - I've had a look and have now found the clipping/cropping tool(s).
However, I still can't find any options to fit planes or solids to point cloud data as there was in Autocad 2014 - does anyone know if they have been removed, or am I just looking in the wrong places??
Do you know the names of the actualy commands in R2014 that you used?
R2015's HELP start page has a 'what's changed' commands/variables list that can help you if you don't find the actual command names listed.
Thanks for that - quite right the commands were an App plug-in.
Unfortunately the plug-in doesn't appear to work with 2015 - which is a shame.
However thank you both for your assistance.
Regards
Does anyone know if this app is likely to be updated to be compatible with 2015 at any stage in the near future? I was planning on using it on an upcoming project.
I don't know whether an update is planned, I did get confirmation that the app was incompatible with 2015 - so have reverted to using 2014 again.
I was informed that the app for 2015 has been uploaded to the Autodesk app site but that it is awaiting approval for publishing. I have made some enquiries as to when this would happen but have had no reponse as yet.
