I am trying to publish some drawings because I have multiple sheets in multiple drawins that all belong to the same project. I was hoping publishing to pdf would cut down on time from doing it to each page one at a time (and saze on file size). Everything is working fine except for when I publish to PDF my maps. The wipeouts that I add so sghow information do not show up, it shows the map behind. If I print the map to a hard copy or use cutepdf to print it, they turn out fine. I tried using color 255, merging and not merging lines in the pc3 file, played with the frames and the drwing order and I have had no luck. ]
I was hoping someone could shed some light. I was hoping for a solution other then publishing to a DWF then to a PDF (seems like extra work that should not have to be done.).
Others in my office and other offices are using hte same pc file and are not having any issues.
Zack
We are having this same exact issue in my office. Did you find a solution?
