Ok all you clever people. This one has got me stumped. I hope I am posting this in the correct place;
I'm trying to write a macro that draws a closed polyline on a layer named "capping". This will then be used as the profile for the sweep command. Here is the macro;
^C^C_-layer;s;capping;;pline;-12.5,0;-12.5,40;7.5,50;67.5,50;87.5,40;87.5,0;c; (the 'capping' layer will always exist in the drawing template)
It works great 80% of the time but every so often the macro will miss a point, sometime two, and the polyline will end up the wrong shape. I've tested this with a couple of users on different workstations.
Any ideas?
i am close to 100% that "osnap" are your problem
( so i get the beer ? )
cw
I did consider that, and tested with all status toggles off. I'm pretty sure that didn't help. I'll need to check this again now to reconfirm, but I don't believe it is the problem.
I'll get back to you on the beer front...
Yep. I think I will do that. By far the most common error is the third point being place right on top of the second. That would strengthen the osnaps argument. I did actually considered an osnaps problem before posting here. I thought i'd ruled it out however, but it would seem my ad-hoc testing methods leave a lot to be desired!
Thanks for your help.
Might even post the rest of the macro that does the 3d bit because there was a few funny things going on with that too.
Chris
Turning osnaps on an off isn't actually all that simple... here's why... please correct me if i'm wrong,
I can't us ^f to turn osnaps off because the might already be off before the macro is launched. This would turn them on, somewhat defeating the purpose. I could write -osnap;off; into the macro. That would turn them of if they were on and keep them off if they were not. Great. But then if I use ^f to toggle them back onthe osnaps dialog box will lauch because all the osnaps had been turned off permanently at the start of the macro.
The only alternative I would see would be to use -osnaps; at the end of the macro to turn on a pre-defined ste of osnaps.. it's not perfect because this will overide users prefered snaps, but it would seem to be the best solution.
Is that about right?
osmode
grap it , store it , turn it to 0 and if you ready turn it back
thats the way it shoud work
cw
I had considered that. using the osmode variable seems to be the most 'elegant' solution
In your routine, do:
(setq old_osmode (getvar "OSMODE"))
(setvar "OSMODE" 0)
... do stuff
(setvar "OSMODE" old_osmode); reset old values on exit.
or use
OSNAPCOORD it will be better if you have a crash use F1 for help
cu cw
