AutoCAD 2013/2014/2015
Distinguished Contributor
jmaeding
Message 1 of 4 (126 Views)
Why does sweep command make items off by a bit?
126 Views, 3 Replies
05-29-2012 04:40 PM
Try this:
Draw line from 0,0 to 100,0
draw a 2x2 rectangle
sweep the rectangle along the (flat) line.
orbit the viw some so you can see the end rectangle.
ID on one of the rectangle verticies, the z values are not 1.0 or -1.0, but 1.05 and -.94
The swept shape is lifted up a bit from what it should be.
I replicated this in 2009 too, so its been around a long time.
Isolines setting does not matter here, its all flat and straight stuff.
Any ideas?
*Pro
nestly
Message 2 of 4 (121 Views)
Re: Why does sweep command make items off by a bit?
05-29-2012 05:35 PM in reply to: jmaeding
I'm not getting an out-of-plane condition, but you are right, the resulting sweep isn't "centered" on the path as would be expected.  It doesn't seem to happen if the profile is already aligned with the path, or if a basepoint is specified.
Valued Mentor
parkr4st
Message 3 of 4 (117 Views)
05-29-2012 05:58 PM in reply to: jmaeding
the only i can replicate your outcome is to draw the path on the xy plane.   Try rotating your ucs and draw the square on the xy plane at 90 degrees to your original xy plane then sweep
Dave
jmaeding
Message 4 of 4 (115 Views)
05-29-2012 06:11 PM in reply to: jmaeding
oh, interesting point.
I draw the shape programatically so that should not be hard.
Will try.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
