Hello All,
I'm stumped.
In our AutoCAD 2012 we have a nice enterprise.cuix that we load as our Enterprise Customization File
in Options >> Files.
I've recently installed AutoCAD 2014 and was hoping I could use the same enterprise.cuix as we do in 2012.
I've got my 2014 configured with our enterprise.cuix as the Enterprise Customization File but it won't display.
When I do a CUI I can see that it is loaded, but no display of any enterprise ribbon tabs ???
Has anyone attempted something like this?
Were you able to get your earlier enterprise.cuix to work with 2014?
Any suggestions on what I'm missing or doing wrong?
Thank you,
Steve
Is there some special programs or add-in or marco combined with the enterprise? If yes, please check those are worked well for AutoCAD 2014. If not, please follow below steps to check.
Firstly, please input CUILOAD in command line to check the enterprise.cuix has been loaded.
Secondly, please input CUI in command line to check that enterprise is active workspace.
If issue still exist, could you provide a screenshot or recordings of your issue?
Hello jingy,
Thank you for all the info.
I've got it figured out.
Everything was loading but I had failed to redo the Workspace to enable the display of my enterprise.cuix's tabs.
Once I updated the Workspace everything appears to be working fine.
Thank you for taking the time to assist.
You can close the ticket you had opened for me.
I have more 2014 questions and will be back.
Steve
