On Layer Manager can't see VP Color and VP Linetype see picture can same one help Thank.
@maxim_k wrote:
Are you in Layout?
What Maxim said. VP overrides only apply to the active Layout/Viewport, so make sure you're on a layout tab. Additionally, remember that VP overrides are controlled indivually for each PaperSpace Layout, as well as each viewport inside the layout.
You may want to try posting in the Mechanical group -- that's not a standard vanilla Acad layermanger you are showing.
The command AMLAYER is called when using the ribbon, tool palette, etc. Change it to .LAYER.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
