Hi good morning, I need help.
In school I left an exercise in visual Basic and AutoCAD and need help,
The problem is that I need to do to get the properties to click a wall for example, what is the height, broad and then do things like operations.
The bad is that it's my first time doing this kind of development with AutoCAD, I would greatly appreciate if you help me step by step
try this. (2014) let me know if you have any issues. you can reference the dll's in the
folder
WindowsFormsApplication27\obj\Debug
Hello thank you very much for the help it works great I just wanted to ask you one thing, when I migrate it to Visual Basic Error muetro what you image, you define with this line and the "Out"
Maybe this will help. See: http://msdn.microsoft.com/en-us/library/ee332485.aspx
GetEntity will set the 'ent' as the entity selected.
So, instead of setting ent like normal (example: AcadObject ent = cad.ActiveDocument.Utility... etc)
It must be set as shown in the image.
the great thing about visual studios is it will give you the required arguements
Hello thank you very much indeed has helped me too, do not know how to thank you. and I did work in Visual Basic, if you ever need help I am here to serve, thank you
