Kindly advise how to find out the feature as attached file in version 2015.
Thank you!!
Solved by Alfred.NESWADBA. Go to Solution.
when you first started AutoCAD 2015 have you migrated anything from older AutoCAD versions?
If you have not done too much customization you might try to reset the AutoCAD profile (from Windows start menu ==> Autodesk ==> AutoCAD 2015 ==> Reset settings to default).
- alfred -
Thanks.
I will try your method to find out, if still can't get it, i will inform you later.
Thank you for your feedback, good to know it's working for you!
- alfred -
