I first noticed this issue in 2012. I decided to see if I could reproduce it in 2014 and it did.
I have OOTB Acad 2014 intalled (no customizations to ANYTHING yet).
This zero length line appears with every sketch I create but only after I save & reopen the dwg file. I routinely use this command to draw things like existing ground for a detail -- because I want something that looks random. There are many times that I'll create a sketch and because I don't like how it turned out, I'll delete it and try again -- sometimes I'll have 3-4 version. So the next time I reopen the file, I might have 4 of these zero length lines. All too often, they're white which in our system plots heavier than anything else so they stick out like a sore thumb.
I've attached the 2014 dwg file that I performed this test in. After creating the sketch, I changed it to RED. When I reopened the file, the zero length line appeared and I drew a green circle around it to draw attention to it.
Is anyone else able to reproduce this issue?
Don Ireland
Engineering Design Technician
Why would you use such a small increment? The best practice is to set the largest tolerable snap increment. Would the same thing happen if you used a 0.1 increment? I don't mind testing but would never use such a small increment.
Don Ireland
@doni49 wrote:
The details I was working on were small scale and I was getting jagged poly lines. I kept trying smaller increments until I found one that gave me a polyline I liked.
No I haven't tested other increments against this issue yet. I was just trying document the exact steps I take when drawing my sketch.
I just now had a few min to spare and tried it in both 2012 & 2014 using an increment of 0.1. Same results in both files -- zero length lines near the start of the sketch.
Don Ireland
Well I don't believe it's related to the increment.
After my last reply, I tried it once more in the 2014 file with an increment of 10 (yes -- TEN). When I closed and reopened my file, I had a zero length line near the starting point.
The 2014 file is attached again.
There are two red polylines in it now. The smaller one is from my previous test (increment = 0.1) and the larger one is from this test (increment = 10).
Don Ireland
I had previously opened a support ticket about this.
The tech had been unable to reproduce the issue.
I just got the following reply.
Don Ireland
Thanks for the followup. I could not repeat your issue with 2014 until I closed and opened it again. Interesting and disappointing. Thanks for reporting it. I think I would just delete the additional zero length polylines.
Don Ireland
