AutoCAD Forum
Unhandled Exception errors in Autodesk products
4 REPLIES 4
ukdxb012
2477 Views, 4 Replies
Not sure if this exists but it would be useful to have...
From time to time we get unhandled exception errors, some of them can be fixed after a bit of research but some of them can be a real problem trying to troubleshoot.
Does anyone know if there is a database anywhere that has the most common unhandled errors documented. Something like a unhandled exception knowledgebase. If you do, could you send me a link please, otherwise we will still have to trust Google Search and the Forums to resolve these issues.
Duncan
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
4 REPLIES 4
Charles_Shade
in reply to: ukdxb012
Other than the KB, Google will be your best bet. Many in the Forums use Google instead of the built in search engine to find information thay need.
http://usa.autodesk.com/adsk/servlet/ps/kb/autoindex?siteID=123112&id=2334144&linkID=9240617
ukdxb012
Hi Charles,
I thought that might be the case... thanks for your input! I'm curious if anyone else might have any other suggestions as these issues are such a pain to troubleshoot.
P.S - I was kind of hoping someone from Autodesk would have thought this is a good idea and setup a knowledgebase purely for these issues or at least document the most common issues and fixes.
Duncan
Duncan Brannan
Twitter | LinkedIn
DarrenP
here is one: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21989963&linkID=9240617
DarrenP
DarrenP
in reply to: DarrenP
if you happen to get on a laptop with Nvidia optimus technlogy
http://upandready.typepad.com/up_and_ready/2013/08/fatal-error-autocad-architecture-2014-2012-geforc...
DarrenP
”Boost
