AutoCAD 2013/2014/2015
Message 1 of 6 (1,263 Views)
Unhandled Access Violation reading 0xffffffff exception at e14572a7h
1263 Views, 5 Replies
02-14-2013 12:06 AM
Hi Everyone,
We're trying to elete an object with a constrain on it in ourdrawing. Problem is, when we try to either delete the object or remove the constraint on it, our AutoCAD 2013 crashes with the error in the subject. Additional detail is that the file was created in a lower version, I'm hazy on it but I think it was created on AutoCAD 2011.
Has anyone else encountered this problem? Thanks. :smileyhappy:
rkmcswain
Message 2 of 6 (1,247 Views)
Re: Unhandled Access Violation reading 0xffffffff exception at e14572a7h
02-14-2013 04:59 AM in reply to: ronane
Is this a crash you can repeat in any new empty drawing, or does this only happen in a particular drawing?
Message 3 of 6 (1,238 Views)
02-14-2013 05:18 PM in reply to: rkmcswain
Hi rkmcswain,
The error is only for a specific drawing.
braudpat
Message 4 of 6 (1,228 Views)
02-14-2013 11:36 PM in reply to: ronane
Hello
Could you open your DWG in RECOVERY Mode and then Re-Save it ...
Have you yet the same problem ?
Bye, Patrice
Bye, Pat
Message 5 of 6 (1,224 Views)
02-14-2013 11:53 PM in reply to: braudpat
Hi Patrice,
Thanks for the reply. We can't open it in RECOVER, it just crashes. It just says  "problems were were detected. recommend that you save your work and restart program."
braudpat
Message 6 of 6 (1,215 Views)
02-15-2013 02:48 AM in reply to: ronane
Hello
Aie, Aie, your DWG seems very damaged !
An other idea : from a blank DWG with correct Units
Try to insert it at 0,0 - Rotation = 0 - Scale = 1 - In exploded mode
If OK, please try immediateley an AUDIT
Good Luck, Bye, Patrice
Bye, Pat
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
