AutoCAD Forum
URGENT HELP.! to embed all xref
4 REPLIES 4
394 Views, 4 Replies
I have received a drawing with 10 xref drawing overlay. I wonder how can I save all the xref with the original base drawing into one file.? Please help. I'm using 2014.!
4 REPLIES 4
Patchy
I thought BIND is the way to glue them together.
darawork
Type 'xr', then right-click the xrefs and choose 'Bind...' then choose either 'Bind' or 'Insert' (Press F1 at this stage to read what each type does).
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
hwalker
Welcome to the Forums
At the command line type in -XREF. Note there is a dash at the front of that command.
A list of different commands will appear. Press B for BIND
It will then say ENTER XREF NAME(S) TO BIND.
Just press * and it should bind all your xrefs as blocks into your one drawing.
Howard Walker
Left Handed and Proud
in reply to: darawork
great.! can't believe it is that easy.  I just upgrade my cad from 2010 to 2014.! cheers.!
”Boost
