AutoCAD 2013/2014/2015
Message 1 of 8 (976 Views)
UNITS Dialog Box not showing
976 Views, 7 Replies
04-20-2012 03:42 AM
when I use the units command I do not get the dialog box.
Please help
Stelios
Alfred.NESWADBA
Message 2 of 8 (975 Views)
Re: UNITS Dialog Box not showing
04-20-2012 04:07 AM in reply to: xantzakoss
as I don't have UN as shortcut please look into your PGP-file and see how it's defined there.
If there it starts with _-UNITS then the command-line version starts, if it's defined by _UNITS you should get the dialog.
You can check this also by typing the command (with and without dash) direct in the command-line.
- alfred -
Alfred NESWADBA
jonmcfarlandWS
Message 3 of 8 (968 Views)
04-20-2012 05:47 AM in reply to: xantzakoss
It should work the way you are doing it.  Try DDUNITS, the old command when the Dynamic Dialog boxes were first  introduced.
Jon
Please select "Accept as Solution" if your question was answered.
curtainwallBIM.blogspot.com
rkmcswain
Message 4 of 8 (963 Views)
04-20-2012 06:14 AM in reply to: jonmcfarlandWS
You'll find DDUNITS in the PGP file under "commands discontinued in AutoCAD 2004"
Why they leave this stuff in there I don't know.
UNITS is the actual command name, and as Alfred mentioned, if it's prefixed with a hyphen, you'll get the command line version.
Message 5 of 8 (958 Views)
04-20-2012 06:20 AM in reply to: jonmcfarlandWS
The ddunits command worked fine. Thank god.
the units command have the same prolbem.
Thank you very much.
I hope someone knows something about "UNITS" command. I guess I am not alone.
stelios
jonmcfarlandWS
Message 6 of 8 (953 Views)
04-20-2012 06:26 AM in reply to: xantzakoss
Stelios,
Glad it worked, although it should have worked the way you were doing it.  You may want to go to your Alias editor (I don't have ACAD open now, but it should be Express Tools>Tools>Command Aliases then change the short cut for UN to DDUNITS.
Good luck.
Jon
rkmcswain
Message 7 of 8 (950 Views)
04-20-2012 06:38 AM in reply to: xantzakoss
stelios
I wouldn't band-aid it by pointing to _another_ pgp file shortcut, an obsolete one at that.
Find out what is redefining the UNITS command.
Try the REDEFINE command and enter UNITS.
Now see if UNITS works.
I suspect someone has create a lisp function that calls the UNITS command, and without a certain function in there, it will launch the -UNITS command (command line version)
This is the proper way to do it with lisp
(defun C:UN () (initcommandversion)(command "._UNITS"))
Message 8 of 8 (946 Views)
04-20-2012 07:01 AM in reply to: rkmcswain
Thank you all so much. the Redefine command worked and now units command works as expected
Thank you
Stelios
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
