Hi all,
I'm trying to get Autocad to use my 'uncertified' GTX760 as its default card.
It keeps reverting to the internal Intel HD P3000 onboard chip.
I have tried changing the BIOS video setting (Auto, PEG & PCI choices only)
Auto: GTX760 not used. Defaults to Intel HD.
PEG (PCI-E device): GTX760 not used. Defaults to Intel HD.
PCI (PCI device): GTX760 not used. Defaults to Intel HD.
The device appears and works fine in 3DSMax Design 2014 (card appears as CUDA device in iRay rendering dialogue).
Anyone know how to get it working with Autocad 2015?
I have the latest driver for the card installed.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
Solved by darawork. Go to Solution.
what makes you thinking that AutoCAD is using the wrong card?
When you have installed the nVidia software you should have the option to right-click onto the AutoCAD icon and chose the graphic card to use for that app.
And there is also the nVidia control panel, there you can set the graphic system to use for every single application:
(sorry for the German screenshot, I have only the German driver installed)
HTH, - alfred -
I don't have a solution for you, but I just wanted to let you know you're not alone. I think Autodesk changed something in how it's reading cards now because pre-AutoCAD 2015 AutoCAD always found my card. It's the same system and I had never changed anything in my BIOS before this. Fortunately for me, I was able to force the use of my graphics card with a BIOS setting (changed from "Auto" to "Enable if no EXT PEG - Disable onboard GPU if GPU exists in the PEG slot").
It's possible that upgrading your BIOS or graphics drivers would help, but I wouldn't hold my breath. I'm hoping Autodesk will resolve this on their own soon. As far as I can tell, they don't have a list of any certified cards for 2015 up yet. I'm just guessing a lot of graphics issues that have surfaced in 2015 so far will be fixed once they've hammered out updated drivers with AMD and NVIDIA and start adding "certified" cards.
Hi Alfred,
I don't have all the settings you have in your Nvidia Control Panel, see below.
It's a bit of a mystery alright.
Darawork
AutoDesk User
I'm installing AutoCad 2015 LT on a few other workstations now, they have ASUS EN210 (GeForce 210)s in them. I wonder if that card will be ignored too?
Darawork
AutoDesk User
LT recognoises the ASUS EN210s alright.
Darawork
AutoDesk User
hi,
What version of nVidia driver do you have?
When you start command _3DCONFIG, what videocard is displayed on top of the dialog?
- alfred -
nVidia driver version is in my signature below.
Screengrab of 3dconfig dialog included below too.
Darawork
AutoDesk User
Here is the tuner log:
Card name: Intel(R) HD Graphics P3000
Driver version: 9.17.10.3062
Tuning Date: 31/03/14
Virtual device: Dx11 (Hardware)
The card and driver meets the recommended requirement.
Display Adapters:
NVIDIA GeForce GTX 760(Primary)
RDPDD Chained DD
RDP Encoder Mirror Driver
RDP Reflector Display Driver
Certification:
Hardware Available True
Hardware Recommended False
Status 0
Hardware ID 2
Hardware Feature Level 50
Software Feature Level 45
General Options:
Adaptive Degradation True
Discard Backfaces True
Dynamic Tessellation True
Generate Vertex Normals False
Handedness Right
Maximum LODs 6
Redraw on Window Expose True
Surface Tessellation Tolerance 92
Transparency MediumQuality
Additional System Information:
ComputerSystem
Manufacturer LENOVO
Model 782436G
NumberOfProcessors 1
TotalPhysicalMemory 21357723648
Processor
MaxClockSpeed 3101
Name Intel(R) Xeon(R) CPU E31225 @ 3.10GHz
NumberOfCores 4
NumberOfLogicalProcessors 4
Revision 10759
OperatingSystem
Name Microsoft Windows 7 Professional |C:\Windows|\Device\Harddisk0\Partition2
OSLanguage 1033
ServicePackMajorVersion 1
ServicePackMinorVersion 0
TotalSwapSpaceSize
TotalVirtualMemorySize 41712444
Version 6.1.7601
DiskDrive
Model ST3500413AS
Name \\.\PHYSICALDRIVE0
Size 500105249280
DesktopMonitor0
MonitorManufacturer
MonitorType Default Monitor
Name Default Monitor
ScreenHeight 1200
ScreenWidth 1920
DesktopMonitor1
MonitorManufacturer HP
MonitorType HP Compaq LA2405 Wide LCD Monitor
Name HP Compaq LA2405 Wide LCD Monitor
ScreenHeight
ScreenWidth
DisplayConfiguration
DeviceName Intel(R) HD Graphics P3000
DisplayFrequency 60
DriverVersion 9.17.10.3062
PelsHeight 768
PelsWidth 1024
VideoController0
AdapterDACType Internal
AdapterRAM 2210398208
ConfigManagerErrorCode 0
CurrentHorizontalResolution 1920
CurrentVerticalResolution 1200
DriverDate 20130308000000.000000-000
InstalledDisplayDrivers igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Status OK
TimeOfLastReset
VideoArchitecture 5
VideoModeDescription 1920 x 1200 x 4294967296 colors
VideoController1
AdapterDACType Integrated RAMDAC
AdapterRAM 2147483648
DriverDate 20140304000000.000000-000
DriverVersion 9.18.13.3523
InstalledDisplayDrivers nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Name NVIDIA GeForce GTX 760
Status OK
TimeOfLastReset
VideoArchitecture 5
Process Information:
Loaded ARX and CRX Modules
acapp.arx
acapp.crx
acautoloader.arx
acgsconfig.arx
acgsconfig.crx
acvmtools.crx
vl.crx
aclaunchnfw.arx
acsign.arx
acetutil.arx
vl.arx
acexperience.arx
acpublish.crx
acpublish.arx
AcPi.arx
acconnectwebservices.arx
acjscorestub.crx
acdim.arx
acdim.crx
AcFdUi.arx
acsecopt.arx
Effects:
ACAD_LineSmoothing supported turned on
ACAD_PerPixelLighting supported turned on
ACAD_AdvancedMaterial supported turned on
ACAD_FullShadows supported turned on
ACAD_TextureCompression supported turned off
Darawork
AutoDesk User
Sorry, have not seen it (not looked to the details within the line).
It's interesting that the _3DCONFIG reports the Intel as used, but the nVidia as "Primary".
If you right-click onto the AutoCAD-icon, do you have the option to choose the graphic card to use? See my (German) screenshot:
- alfred -
Finshed work now, will check tomorrow. Thanks.
Darawork
AutoDesk User
Nope, that menu does not exist with my current card / driver.
What card / driver are you using?
Darawork
AutoDesk User
Well, my ideas a at the end now (for the moment), sorry!
On my current notebook I have a Quadro K1000M, and my driver version is 332.76, but I had also to update my drivers before I get my cursor clean in AutoCAD 2015.
- alfred -
Ahh, it must be one of the purported features of Quadros fabled 'Optimised Drivers' then.
Darawork
AutoDesk User
Not really, I only installed the default driver, the "Performance Driver for AutoCAD" does not work since many releases now for AutoCAD, I guess the last was for 2009 or 2010, when AutoCAD let gc-vendors install there own drivers additional to the standard ones from Autodesk.
The driver I installed, is this one:
- alfred -
Just an update for those of you with AMD FirePro cards. I've been in contact with a representative at AMD who told me the drivers on their website do not currently support AutoCAD 2015. He said they expect to have a driver that supports AutoCAD 2015 by the end of April.
AutoCAD has updated their list of certified cards, but the certified driver they're listing for my card (and most likely all AMD cards) is inaccurate.
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534
I've been on to nvidia too, for GTX support. I'll let you know if something happens, they say there is a Beta up on the driver page now. But not sure if it's working yet as I am away from the workstation.
Darawork
AutoDesk User
Beta Nvidia driver didn't work. Card was/still not seen by AutoCad 2015.
Card works fine with iRay in Max Design 2015.
Need to catch up lads 🙂
Is there anyone else here with a GTX760, and AutoCad 2015?
Darawork
AutoDesk User
darawork,
I was looking at your post the other day and thought I saw a solution you cam up with.
If so, can you repost?
Thanks.
Darawork
AutoDesk User
