I'm using AutoCAD 2014. Nothing special.
When we upgraded from 2013 I migrated all of my tool palettes and settings over to 2014 earlier this year. All seemed normal up until Friday when I created a new palette. That part was normal, but when I tried to drag a block from Design Center to that tool palette it wouldn't populate. It seemed like it was going to, it gave me that typical >--------< under where the block would show up in the tool palette, but when I tried to release it in the palette, nothing.
Additionally, if I right click on a directory/folder in design center and select "Create Palette of Blocks" (which I have done a million times before), it will create the tab of the directory/folder I have created but does not pupulated it with the blocks within that directory/folder. Leaving me with a blank Tool Palette.
Any ideas??
Ted K.
I had a similar issue. I have a tool palette on a network, with 2013 I had no problem making changes to the tool palette and haveing changes be visible to users on next AutoCAD session.
Now I find I have to delete the path on Tool Palettes File Locations. When you hit apply AutoCAD uses the default location. I then repath it to my custom Tool Palettes and all is good again. Hope this helps.
