I'm having trouble. I Xreffed my Profile Border (title block) into paper space then xreffed my profile.dwg into the model space. When I plot, the gridlines from the border plot on top of the profile lines. Is there way to change the plot order of the Xref files?
Sonny
DRAWORDER fix everything from the first file up to the top file not work?
Are you using a PC3 file? Perhaps resetting LINEMERGE would help too.
In pagesetup, under plot options, uncheck "Plot paper space last".
I tried DRAWORDER but it wouldn't let me select an XREF that is XREFfed in model space. Also I tried to uncheck "print paperspace last" it worked for the gridlines but I also have a plan view on the sheet and anything I used wipeout on showed up again.
Personally, I don't go for plottable grids that run across the sheet sourced from the titleblock - way too complicated. For your situation, if you don't have multiple viewports, you might benefit from putting everything in model space and only put a single non-plottable viewport in paper space set up to see both your scaled titleblock and model space. Then draworder might work.
