AutoCAD 2013/2014/2015
Message 1 of 3 (193 Views)
These surfaces will not extend!!! ugh help!
193 Views, 2 Replies
07-11-2012 08:20 AM
I have a file I imported, it was a solid CATPART file apparently from Catia.
the solid comes in o.k. into 2013 and then I have tried converting it to surfaces and also converting it to nurbs surfaces
After doing this the surfaces will trim, but will not extend.
All I get is a "not valid object type" report.
I have even tried to export the surfaces out, then back in and still get the same response.
I attached the file if anyone would like to look at it...
Is there a solution to this?
Thanks!
*Expert Elite*
Message 2 of 3 (185 Views)
Re: These surfaces will not extend!!! ugh help!
07-11-2012 10:37 AM in reply to: hypersonic
Why would you convert that to surface to edit?
What do you need to change?
I think I would use solidedit in AutoCAD
or
Inventor Fusion
or
Inventor to do the edits.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 3 of 3 (165 Views)
07-12-2012 06:30 AM in reply to: JDMather
Thanks JD, but I am trying to get to the bottom of why these surfaces will not edit properly, if it is a bug created when importing from CATPART files, then Autodesk might want to know.  In all the other testing I have done the surface extend feature has been the best "comeback" to surfacing capability I have seen in autocad since they got rid of most of the surfacing capabilities that were built into Mechanical Desktop.
I would like to encourage them to continue to improve the surfacing capability.  If they could get the surfacing capability back to where it was in 2004 I would stop using 2004 and buy a newer version.
Thanks for the input though.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
