Please help me because every time I opened the software it gave me that message. The drawing file being opened was not created by a product from an autodesk education suite. If you save this drawing, it will always be plotted with the following plot stamp: Produced by an autodesk educational product it is recommended that you save this drawing with a different file name.
All it tells is that
1) the drawing was not created by AutoCAD student version.
2) the person who sent you the drawing saved it by using a student version of autocad and the stamp can't not be removed.
From its license agreement, the student version can't be used for commercial purpose.
HTH
If the message states "was not created" then it means you are using an eductional version of AutoCAD. The dwt (template files) you are using are from the standard autocad version. To keep from getting that message open and save any dwt files you use.
