AutoCAD 2013/2014/2015
New Member
Message 1 of 5 (2,207 Views)
The acadlt.pgp (AutoCAD LT 2013) is missing. Please help
2207 Views, 4 Replies
12-12-2012 08:13 PM
Please help. The acadlt.pgp of my AutoCad LT 2013 is missing. It was working perfectly fine until yesterday. When I about to use the AutoCad again today, I could'nt use the shortcut commands / aliases anymore. I already search for by the AutoCAD program by following the guidelines and even searching it manually, still I could not find it so that I can edit the acadlt.pgp. Please help. Thanks
rkmcswain
Message 2 of 5 (2,196 Views)
Re: The acadlt.pgp (AutoCAD LT 2013) is missing. Please help
12-13-2012 04:27 AM in reply to: ada.esmanil
Run a repair, or search your original install media for it.
The english version for a 64bit install is located here:
D:\x64\en-US\acadlt\Aclt\Program Files\Root\UserDataCache\en-us\Support
pendean
Message 3 of 5 (2,191 Views)
12-13-2012 05:31 AM in reply to: ada.esmanil
All support files are under your Windows Profile, most likely hidden folders, probably why you cannot find it.
In LT2013, at the commadline, type PLOTTERMANAGER. When Windows Explorer opens up as a result of typing that command, go up ONE folder until you are in the ENU folder, then open the SUPPORT folder and that is where your PGP resides in that session of AutoCAD LT.
If none is there, AutoCAD/LT stores spare copies in the folder:
C:\Program Files\Autodesk\AutoCAD LT 2013 - English\UserDataCache\Support
Just copy what you need over (don't move it).
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Distinguished Contributor
greg.battin
Message 4 of 5 (2,187 Views)
12-13-2012 06:10 AM in reply to: ada.esmanil
How convienient... I recently just did a post about how to show hidden files. This will allow you to navigate to one of your support paths...
http://autocadtips.wordpress.com/2012/12/10/how-to-show-hidden-folders/
If the goal is to navigate to the support path that is inside of the "AppData" folder, here's how:
Shown below is the user name folder with hidden folder not being shown. ( My user name on my computer is "Trog" yours will be something different...)
While you are in this folder, simply press the ALT button,
You should now see some buttons appear along the top of Windows Explorer
  • Click "Tools"
  • Click "Folder Options..."
Click the View tab to make it current
In the list, scroll down and check the toggle next to "Show hidden files, folders, and drives"
Also - while you are in this dialog, you might as well make sure that the display of file extensions is turned on... (shown below)
After you close that window, you should now see the AppData folder kind of faded. The faded folders are "hidden" folders that you can now browse to.
You can also navigate to the AppData folder by clicking the Windows start button and then type %appdata% into the search prompt
Shown below is the overall AutoCAD support folder path that is shown on my computer.
Your acad.pgp should be in here...
New Member
Message 5 of 5 (2,168 Views)
12-13-2012 05:31 PM in reply to: ada.esmanil
Thanks for all the help from the three of you. I have done all the things you three said, I have already tested it and the command/aliases are back again. Thaks again for the great help :smileywink:
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
