I just have to say this: The Ribbon Sucks.
I upgraded from 2006 to 2014 a few months ago and I have to say that the ribbon just sucks. I had to get my hardrive worked on and have to use a temporary set up for a week or two. I cannot really customize AutoCAD with this temporary set up so am forced to use the ribbon. It is just terrible with all that switching around and pulldowns you have to wade through and who knows where the hell the commands are located. Not to mention the screen space it takes. Did I mention how badly it sucks?
Yuck!
End of Rant.
Thanks for listening.
Just turn it off (Ribbonclose).
Isn't the "AutoCAD Classic" workspace still available?
I jumped from 2005 to 2013, and decided to give the Ribbon an honest try. It actually took longer than I expected to "learn" where all of the commands where - but, I have to say that I'm glad I did. I love the Ribbon now and will never go back to "Classic" mode.
Just my 2 cents.....
I'm beginning to get used to the ribbon in MS Office software, but there I don't see how it works better than the toolbars and menus, particularly if one has spent years learning how to work with them. It seems to me that it's just the same stuff re-arranged (for the sake of being "new and different"), which basically just means I have to learn how to work with it all over again, without any advantage that I can see.
The Ribbon is awsome!
Do toolbar enthusiasts still prime the engine and crank their cars to start them to drive to work in the morning?
Unlike toolbars, Ribbon panels automatically shrink when the window is made smaller (e.g. using a mobile device or remote login). They don't utilize a number of the features I like though, like dragging panels off for toolbars or expanding/folding panels.
Some of us don't bother with cars and driving at all - ever heard of telecommuting?
(The car analogy doesnt really work, though. The technology you refer to in older car models is clearly inferior, less reliable, and less desirable than the technology available in modern cars. The superiority of the ribbon over toolbars and menus is not so clear. It's really a subjective, preference issue, as far as I can tell. That's why there's so much debate and disagreement over it.)
Like someone mentioned previously, you can minimize the Ribbon to 3 different levels. It's the button to the right of the last Ribbon tab. Try it out.
I would also add that the Ribbon has contextual tabs that can replace those dialogs that cover your screen, like Hatch and Array.
Also if you have trouble finding a command in the Ribbon or even Toolbars, you can use the search box in the Application Menu (big A button in upper left). It will show you where they are...
@dmfrazier wrote:Some of us don't bother with cars and driving at all - ever heard of telecommuting?
I contend the car analogy works exactly as I intend it to... it's an extreme statement to throw an extreme practice into sharp relief. 😉
A wise man once said, "I do not know what I do not know", and to prove this point about myself;
What happens when the Ribbon is off and you select the frame of a PDF underlay? (this is a real question since I don't know)
I suspect that you simply don't know what you're missing by bypassing a contextual Ribbon!
In my experience, toolbar hold-outs largely;
I've heard that those who use toolbars exclusively will be featured in the next Tim Lahaye novel (you know, the 'Left Behind' series)?
Now, another wise man once said, "All generalizations are false, including this one". I'm trying to "make lite", but I'm really not kidding too much.
There was a joke-type application I saw once which went through a faux installation scenario. One of the options was:
I know that, after this number of years (yes, years) it might be useless to have this conversation, but perhaps someone will give the Ribbon a 30-60 day evaluation. I resisted for one release then gave it a fair shot... I'll not go back by choice.
P.S. I meant to mention that effective use of the .pgp, Toolpalettes and .cui (especially for adding rt-click functionality that fits your workflow) makes the Ribbon vs. TP choice somewhat less relevant.
The ribbon cannot do DIESEL expressions like the MENUBAR.
$(substr,DIMSTYLE: ,1,10)$(getvar,dimstyle)
Also, for a top level command (IE the command is not buried in a drop-down), if you do not have an associative
button image and wish to switch the Button Style to "small with text", thus using only text, this is what you get:
Also, take a look at the genius who wrote this:
No mention of the Screen Menu, huh?
Ribbon:
One click on the appropriate tab, one click to expand a drop-down, one click to start the command.
Menubar:
One click on the menu, one click to start command.
Screen Menu (and toolbars):
One click to start command.
Commandline:
USE THE LEFT HAND TO START THE COMMAND VIA YOUR CUSTOM PGP. What else do you use this hand for?
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
@scot-65 wrote:The ribbon cannot do DIESEL expressions like the MENUBAR.
Search help for "DIESEL Expressions in Macros"
@scot-65 wrote:...
Commandline:
Right... that seems to support that having every command I MIGHT want to use on-screen at all times is not the only (or even the best) option?
Did you notice my qualifier, "In my experience"? That's my story and I'm sticking to it!
Um, ZOOM can be done by rolling the mousewheel (BTW, "W" is not required... just make the window and ZOOM EXTENTS is a dbl-click on the mouse wheel). 😉 Esc is done with the little finger or a slow right-click (enabled slow-right clicks, right?).
My point is that people stuck in the TB mindset are... well... stuck!
I think you've just stereotyped yourself every bit as much as you have Toolbar users you are attempting to stuff into a pigeon hole 😉
I understand that there's nothing personal in this conversation... I truly appreciate when people are passionate about things! You are appreciated! 😉
