Is there something in the setup files that I'm not seeing?
I need to change the text and tab sizes in my AutoCad Status Bar and Drafting Settings so that my old eyes can even make them out without a magnifying glass. I'm in the process of learning Autocad and it would surely be of help that I could see what I'm suppose to be learning instead of having to learn Braile First.
Solved by skintsubby. Go to Solution.
Ronald
Those will be Windows settings.
What version of Windows are you using?
Mark
Ronald.
It is definitely a Windows setting. I'm on Windows 7 and can't tell you where it is on Windows 8.1 But as a starter (and assuming it hasn't changed too much) try right clicking on the desktop and "Personalize" and look under "Display".
For info... You can change your command line text size through "Options" in AutoCAD though.. see below
