AutoCAD Forum
Text size change
3 REPLIES 3
Ronald4418
807 Views, 3 Replies
Text size change
Is there something in the setup files that I'm not seeing?
I need to change the text and tab sizes in my AutoCad Status Bar and Drafting Settings so that my old eyes can even make them out without a magnifying glass. I'm in the process of learning Autocad and it would surely be of help that I could see what I'm suppose to be learning instead of having to learn Braile First.
3 REPLIES 3
skintsubby
in reply to: Ronald4418
Ronald
Those will be Windows settings.
What version of Windows are you using?
Mark
Ronald4418
in reply to: skintsubby
I'm using Windows 8.1 Professional. I've tried all of the Window settings including the Font Sizes and resolution to 1920 by 1080 and the closest I've come is to change the Icons in the Drafting Settings Toolbar to Labels. It helps some and is a little easier to read. But is there a better solution as I imagine I'm not the only user with old eyes?
skintsubby
Ronald.
It is definitely a Windows setting. I'm on Windows 7 and can't tell you where it is on Windows 8.1 But as a starter (and assuming it hasn't changed too much) try right clicking on the desktop and "Personalize" and look under "Display".
For info... You can changeCommand Line.PNG your command line text size through "Options" in AutoCAD though.. see below
”Boost
