AutoCAD Forum
Text not filled
9 REPLIES 9
Message 1 of 10
rcallison
13243 Views, 9 Replies
Text not filled
I have a drawing that is not showing the text filled.  It was fine and now the text shows the outline only.
9 REPLIES 9
Message 2 of 10
dmfrazier
in reply to: rcallison
Check to see if your current view is plan to the UCS.
Message 3 of 10
pendean
is SHADEMODE set to anything other than 2D?
Did you turn off FILLMODE variable? FILL command?
Is your UCS rotated?
is your viewport set to HIDE?
Message 4 of 10
rcallison
in reply to: pendean
I checked all the above and those settins are correct.  The UCS is not rotated.
The text is in paper space
Message 5 of 10
pendean
Can you post the DWG file? delete any sensitive information but ensure the problem is present before you post it.
Message 6 of 10
dmfrazier
Does the text have a Z-coordinate value other than 0 (zero)?
Message 7 of 10
rcallison
in reply to: dmfrazier
The Text Z value is 0
Message 8 of 10
rcallison
The text is a title block located in paper space.  If I make a block from another drawing file that is part of the same project and insert the block the text is still not filled.  If I open the block file it is fine.  The text shows correctly in cadd.  However when plotted and plot preview the text is not filled.
Message 9 of 10
pendean
Do you have HIDE selected on the PLOT pop-up?
Is SHade Plot set to anything other than AS DISPLAYED on the same PLOT pop-up?
Message 10 of 10
3wood
TEXTFILL controls whether TrueType fonts are filled-in for plotting.
Set it to 1
”Boost
