AutoCAD Forum
System variable for hatch selecting
2 REPLIES 2
jdb
1292 Views, 2 Replies
Good afternoon,
What is the command (system variable ?) to change how and what you can select in hatch pattern.  Currently I can only selection the entire pattern.  I need to be able to select an intersections of two lines within the hatch patter.  I have had to ask this every time I switch versions. I promise to write it down this time.
Thank you
2 REPLIES 2
3wood
in reply to: jdb
Set OSOPTIONS to 1 or 3.
jdb
in reply to: 3wood
Perfect!  Thank you!!
”Boost
