Good afternoon,
What is the command (system variable ?) to change how and what you can select in hatch pattern. Currently I can only selection the entire pattern. I need to be able to select an intersections of two lines within the hatch patter. I have had to ask this every time I switch versions. I promise to write it down this time.
Thank you
Solved by 3wood. Go to Solution.
