Hi all,
I got this situation, on my PC I don't have the MatchProp, Sub/Superscript icon when I select my Mtext object. On the other hand on the other PC, the guy got it.
Any one having the same situation and having any clues how to solved this issue.
Thanks in advance
Cheers
Joel
Are you running AutoCAD 2015? Those features are new to 2015.
Hi nrz13,
Sorry, I forgot to mention that we use AutoCAD 2015. Yes you are right. I install AutoCAD 2015 on 3 PCs and I'm the only one who don't have those features as shown below.
Cheers
Joel
Do they show up in text toolbar per my screenshot below?
I don't use the Ribbon, so I'm not sure why icons would be missing. The only other thing I can think of to suggest is clicking on the "Formatting ▼" button at the bottom to see if the icons are hidden under there. If it works like the MS Office ribbon, the more frequently used commands will show up while the less frequently used ones will be hidden there.
Sorry I can't be of more help. Someone else here may be able to chime in with something more useful. It's odd that it shows up in the Text Formatting toolbar, but not in the Ribbon. It's possible something went wrong in your install and a reinstall could fix it.
Just to say that I repair without luck and after that I reinstall it without joy, really strange.
Cheers
Joel
