Good afternoon,
I was wondering if there is a way to convert many regular fractions to stacked fractions without editing each one. I have a file full of fractions that all need to be stacked. It seems it would be quicker if I could select all the fractions and stack them at once rather then edit each one individually. Thanks for any help.
If you have one dimension that's stacked use the command MATCHPROP and select it then select all the dimensions you want to match it.
I will give the lisp routine a try. The 'matchprop' didn't work for me. I checked the settings in 'matchprop' and I have everything checked. Am I missing something?
Thanks.
