Hi everyone,
I searched and found case of "Inconsistent face-body relationships". But it not answer my case.
I had create solid and 3 surfaces. All 3 Surfaces are create from the same programing code, just different vertexes.
With an attachement, the green surface can be used to slice the solid BUT not those 2 red surfaces.
Please help,
what AutoCAD release and servicepack (and vertical product, it any) are you using?
I tried it now with AutoCAD 2015 wihtout issues, see attached.
- alfred -
Thank you Alfred,
I'd tried both ACAD2013/2014 (SP1), and fail on both. Not 2015 which is not the target for now yet.
ok, can reproduce it with 2014 (the message with inconsistent faces).
Different positions or also different order?
But as AutoCAD 2015 is able to do that I guess it's more an unsolved issue, so I'm not sure at all that you can solve it within your app.
- alfred -
Hi Alfred,
Thanks again. 3 Surfaces just different in positions. I will be happy if Autodesk could debug and point out which part that cause , the solid or surface, and also how?. Then I can prevent this situation in my program.
AFAIK: To get a feedback from Autodesk directly is not guaranteed here; therefor you have to create a support case in your subscription center.
Good luck, - alfred -
